I just got a set of w8s to update intake port on it is by far the smallest intake port I have seen in a w8 casting. I would love to know what they were run on.
Intake port 252cc. Port is 2.090" by 1.250"
SMALL!!!! ;-( Picture of my port vs the w8s
are you able to tell what size bore these head were used on. and are the exhaust ports smaller as well. I cant tell from the pick but looks like it has a very large water outlet.BRETT your RND is second to none I LIKE ALL SMALL BLOCK INFO...............
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
