Send him a 1099 and add a zero
Nice work Monte
That actually did cross my mind, Ray...
Invoice showed up in an mail last night, and surprisingly I didn't get a explanation/excuse like Jeremiah got because he doesn't have one...
Hey Monte, why did you charge me to flow two systems when you only flowed one? I'd think that flowing nitrous through both sides of a Fogger nozzle for EFI would be the same amount of work as flowing nitrous and fuel through one Fogger nozzle ??
![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
plus you charged me $800 for that when you'd told me two years ago when I PREAID you it would cost $500 for flowing one stage? I could go on and on, but I'm sure it wouldn't do at good any way...
Dealing with you has knocked the wind out my sails...I never thought in a million years that when I prepaid you that it was going to take TWO FULL YEARS to get a camshaft and an intake plumbed and flowed....
![puke puke](/ubbthreads/images/graemlins/custom/puke.gif)
I respect your knowledge, Monte, but I have no respect for how you run your business and the sad part is, it's really not that hard....all you have to do is do what you say and put work in line as you get it and do it in order...
What's funny about all this is that I could have plumbed and flowed my junk myself, but I sent it to you to spend some money with you because you're always whining about how broke you are and this is how I get treated....
Was going to ignore you, but you just won't let it go and seem to want to do it publicly, so how about the other side of the story.....As usual, you would be thinking WRONG. You can recover fuel used to flow the fuel side and use it over and over. Nitrous is GONE, in the air.......so regardless of one nozzle or two, if you flow 2 dry stages, even through one nozzle, you use twice as much nitrous as a single wet kit. And there is ALWAYS an additional charge for more than one stage and you admit you have 2 and you KNOW I get $500 for a single, so you got a $200 break
I don't grind the cams, I just order them.
Well then you SHOULD have plumbed and flowed it yourself. You have no issue putting on nitrous classes yourself and using MY info........so knock yourself out, if it is so easy. When you said you wanted to do some classes and that you had your own bench built "just for your amusement" and you had no intention of doing any nitrous work, yet have told me yourself you have done some for local guys. Also said you would refer all the guys in the classes to me for work.......NOT ONE has sent me anything, or even called. That's seems kinda strange.....although a few have called to order Holley parts..........so maybe I should just set you up as a dealer and you can get that business to.
And lets not act like you JUST got your intake. You have had it quite a while and refresh me........but is the car running yet, or do you even have the motor?
Yes, I admit, I had the intake a LONG time. But YOU told me you were not in a hurry, as you had all the block problems, plus I was really busy, so again, YOU said no hurry, get it when you can. So I put it on the back burner and basically forgot about it on the shelf, then you got your panties in a wad.
Talking about respect, all the while throwing me under the bus. Whatever makes you feel better. You just figure up how much you think I should owe you, let me know and consider it DONE and you won't have to be disappointed ever again........at least not with me
