One, you should be posting in a different section, this is the RACE section.
Two, the solid flat tappet is better because all the roller lifters as of late have very high failure rates....IE, lack of quality control. I am sure Barton told you that when you talked with him. If you go roller, better be prepared to send them back for checking regularly or risk a bigger problem.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
