Combustion chamber volume 58cc Intake runner volume 225cc Exhaust runner volume 62cc Intake valve diameter 2.15" Exhaust valve diameter 1.60" Valve stem diameter 11/32" Valve guides Manganese bronze Deck thickness 5/8" Valve spring diameter 1.55" Valve spring maximum lift .650" Rocker stud N/A Guideplate
N/A Pushrod diameter 5/16" Valve angle 16° Exhaust port location Raised Spark plug fitment 14mm x 3/4 reach, gasket seat Made In USA
This is the head to run in ultra if it flows anywhere close to what they say.
planning on a big block at this time UNLESS I happen to find a GOOD block.
With the 16* valve angle you fall into the plus or minus 2* rule from stock. So you can run these at a stock valve angle weight. So a r3 at 440 cu inch with these heads could be 3050 lbs.
Brett Miller W9 cnc'd heads STR Chassis fabraction
