Uncledon - sorry but I've opened up a bit of a can of worms...and your question has created a debate that may be more challenging than you realise.
On the topic of it being a "simple choice" - I'll just say this....
I'm not so sure ANYONE on this board would run this stick on a carb set up given a choice.
This stick went in at 114 ICL - as indicated it would by the supplier.
However, suggesting people run a cam that's 4 deg retarded from straight up...and 8 deg off from the recommended ICL...???
Well if you asked the W2 flat tappet boys to do that..they'd fall over themselves laughing.
Trouble is...there is no choice if you are going to run factory slugs on a G3 Hemi.
![](http://i467.photobucket.com/albums/rr34/TheRatPatrol/Diary%20of%20the%20Rat%20Patrol/The%20Hemi%20Years/Intertiacam_zps5f6da69e.jpg)
