Pedal height - just to clear up what I mean. The pedal is physically at the right height, up tight against the brake light switch. It just does seem to grab until about half way down and then can't push it beyond 75% down - hard as a rock. Feels like brakes have no bite..
We're on to something with this (clarification). I would buy a pair of brass inverted flare male fittings to cap the MC & if it is good (& bled out) the pedal will be rock hard with virtually NO travel. Those "Edelman" fittings are cheap & you will reuse em. How about we get the MC cleared away as the culprit (I think it is guilty). It ain't the pads. with my (earlier mentioned) dart that is somewhat similar to your conversion there is a very slight bit of pedal travel & it's rock hard. EDIT If you have a MC fitting/line pigtail handy you might flatten the line end & install it in the disc port & see if the pedal is now rock hard/virtually no travel. OP post what it ends up being cuz we got bets on this one
