Quote: Depends how bad it is, if you have to flat mill shaft saddles and make blocks to change shaft height and/or offset the shaft it will be considerably more expensive than just checking it. Plus you may need new pushrods if moved much.
ok if a builder can guarantee me 46 horsepower for a few hundred bucks I am in if not I'm back to not caring
