Quote: so what we're talking here is less than a 1% difference? thanks but i'll concentrate my efforts elsewhere long as it's not damaging parts i'm ok with it if i should ever decide to run comp eliminator maybe i'll revisit that position
46 horsepower at the 5800 shift point is a bit more than one percent. If you are referring to peak power, that isn't where you shift the motor.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
