Quote: Depends how bad it is, if you have to flat mill shaft saddles and make blocks to change shaft height and/or offset the shaft it will be considerably more expensive than just checking it. Plus you may need new pushrods if moved much.
ok its a builder can guarantee me 46 horsepower for a few hundred bucks a min if not I'm back to not caring
You know what I don't care about? It's you not caring. Listen, if you want drama, watch a soap opera. If you are truly interested in participating for the betterment of all, by all means, do so. Otherwise, step aside son, and let the grownups have a meaningful discussion.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
