None of the alternators listed above put out many amps at idle. I used a CS144 and a $35 adapter bracket. I did have it rewound and had a heavy duty rectifier put on it.
It puts out 115 amps at idle and can deliver over 225 amps if needed. I did have to run 2 gauge wire to a front mounted distribution lug, but it does have remote voltage sensing and a wire for the little light you are looking for.
Do have a freezer in your trunk? Why would you need that many amps?
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
