Quote: I didn't say the taper was too small, I said maybe too low on the shaft. If a manufacturer is unable to supply the correct castle nut can that same manufacturer be relied on to machine the taper correctly on a shaft? All it would take is 1/4" off.
Im still waiting to hear where in the recall notice it says over tightening the nut causes ball/socket to come apart. I think theres some spin going on here.
