Re: Opinions wanted, what would you change? Budget Build...
[Re: MadMopars]
#1663020
08/24/14 10:57 PM
08/24/14 10:57 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I also tried a Holley 850 in place of my 750 Silver Claw and the car slowed down if you can believe that. I still don't quite understand that. With the Tunnel Ram, I run two 660 CFM Holley's and it loves it. I was just trying to keep the motor under the hood for now though.
As you have said the 850 Holley slowed the car down, usually when you add more air and fuel to 440 Mopars they go quicker and faster, I wonder what was or is wrong with that carb? Are you able to jet the carbs, both the single and duals, up enough to slow the car MPH down in the 1/4 mile? If not, pressure is not volume, there is a reason for that(not getting it fat enough to slow the car down, lack of fuel ) If so continue on One thing most guys don't try is to put in a lower 1st gear set I've done that several times using the Mopar brand helical cut 2.77 low gears, that wakes up the beast on the starting line As long as the rear tires will hold it 2.45x4.56= 11.172 starting line ratio, 2.77x4.56= 12.631 ![](/ubbthreads/images/graemlins/shruggy.gif)
Entire Thread
MadMopars
08/24/14 08:10 PM
Pacnorthcuda
08/24/14 08:22 PM
MadMopars
08/25/14 12:30 AM
Sport440
08/25/14 12:41 AM
MadMopars
08/25/14 01:03 AM
pittsburghracer
08/25/14 01:21 AM
72Swinger
08/25/14 01:39 AM
tex013
08/25/14 02:18 AM
dvw
08/25/14 02:40 AM
B3422W5
08/25/14 03:31 AM
Sport440
08/25/14 05:10 AM
Crizila
08/24/14 08:29 PM
MadMopars
08/25/14 12:47 AM
RUNCHARGER
08/24/14 08:42 PM
justinp61
08/24/14 09:07 PM
clonestocker
08/24/14 09:54 PM
AAR-B4
08/24/14 10:23 PM
MadMopars
08/25/14 12:59 AM
Cab_Burge
08/25/14 02:57 AM
sixpackgut
08/25/14 03:21 AM
'72CudaRacer
08/25/14 03:44 AM
383man
08/25/14 05:05 AM
383man
08/25/14 10:13 PM
MadMopars
08/25/14 07:31 PM
mshred
08/25/14 08:26 PM
Sport440
08/26/14 04:57 PM
gregsdart
08/27/14 12:36 PM
JohnRR
08/25/14 06:25 PM
68cuda440
08/28/14 04:06 AM
B3RE
08/28/14 09:27 PM
451Mopar
08/25/14 07:30 AM
gregsdart
08/25/14 01:58 PM
74yellowduster
08/25/14 02:06 PM
mshred
08/25/14 06:08 PM
OUTLAWD
08/25/14 06:43 PM
B3RE
08/25/14 11:08 PM
MadMopars
08/25/14 11:34 PM
2boltmain
08/26/14 12:53 AM
B3RE
08/26/14 12:58 AM
MadMopars
08/26/14 06:04 AM
viperblue72
08/26/14 06:25 AM
B3RE
08/26/14 01:48 PM
MadMopars
08/26/14 06:26 PM
B3RE
08/26/14 07:03 PM
JohnRR
08/26/14 09:06 PM
Paul_Fancsali
08/26/14 09:47 PM
Sport440
08/26/14 09:46 PM
B3RE
08/26/14 10:47 PM
MadMopars
08/27/14 12:31 AM
clonestocker
08/27/14 12:45 AM
pittsburghracer
08/27/14 01:16 AM
B3RE
08/27/14 01:41 AM
pittsburghracer
08/27/14 02:25 AM
B3RE
08/27/14 02:55 AM
B3RE
08/27/14 01:35 AM
MadMopars
08/27/14 03:22 AM
B3RE
08/27/14 03:51 AM
viperblue72
08/27/14 04:32 AM
B3RE
08/28/14 09:09 PM
forphorty
08/27/14 05:57 AM
B3RE
08/28/14 09:20 PM
B3RE
08/27/14 04:06 AM
MR_P_BODY
08/27/14 04:34 AM
viperblue72
08/27/14 04:55 AM
B3RE
08/28/14 09:17 PM
viperblue72
08/28/14 09:23 PM
B3RE
08/28/14 09:31 PM
JohnRR
08/28/14 09:32 PM
B3RE
08/28/14 09:50 PM
74yellowduster
08/26/14 03:52 PM
an8sec70cuda
08/26/14 04:14 PM
dogdays
08/26/14 04:33 PM
MR_P_BODY
08/26/14 04:44 PM
MadMopars
08/27/14 08:27 AM
MadMopars
08/27/14 08:52 AM
viperblue72
08/27/14 12:40 PM
an8sec70cuda
08/27/14 02:04 PM
J_BODY
08/27/14 03:50 PM
GTX MATT
08/27/14 06:03 PM
67Satty
08/27/14 06:30 PM
PorkyPig
08/28/14 09:43 PM
JohnRR
08/28/14 10:44 PM
