Mass
I use dupont chromabase on almost everything now... mixed 1 to 1, a gallon will do a car in and out. Been using it and dupont clear for years. I used to use ppg, too expensive and not any better in my opinion than dupont.
Guy I know had his high dollar 71 curious yellow GTX painted using Dupont instead of PPG who has the orignial formulas for the colors. Guess what...... WRONG color and now he has to live with it at every show, so much that he quit showing the car. He wishes now he would have spent the money for that too expensive paint.
And there's no guarantee that ppg would have been correct either if it was mixed wrong... so sounds like the painter or who mixed it is to blame, not dupont!
Why would the PPG supplier who has the correct formulas and equipment mix it wrong? The chances of that are 1000 to 1.
The dupont system does not have the correct color formulas for these cars like PPG has. So it is your choice. Guess at the color with Dupont and let them try to match the paint on an old part of the car or try to pick the correct yellow off a Dupont paint chart. There isn't one on their charts for curious yellow.
OR just get the correct color from PPG?????? I don't care who's paint YOU use, but without any doubt PPG has the color formulas that are correct for these cars. They were the original paint supplier.So at least you are starting out with the correct color.
The painter didn't mix it the Dupont supplier did with out the original formula. That's why it was wrong.
And like I said, "or who mixed it is to blame" There have been colors I haven't been able to get, I don't have them guess and mix it, hoping it's the right color. So it's duponts fault someone screwed up mixing it? You can't blame a whole line for one persons mistake
I have used PPG, I never said it's bad paint... I said it's too expensive. Doesn't mean I won't use it, but I try to avoid it when possible. And having used both many times, I see no advantage other than sometimes the color does match better, but not always.
Like I mentioned earlier, but I guess you didn't read it?, paint formulation in the last few years while trying to comply with VOC compliance, amongst other industry regulations, plus computer formulation/programs, has become streamlined, many mix formulas no longer support chemicals long gone due to VOC, plus the elimination of ALTernate formula/tints, or combining them into one formula has changed many mix formulas thru the entire paint industry, regardless of manufacturers, I'll give you an example of your "revered" PPG "original formulas" ....you go into the PPG computer program for 1970 PPG Plum Crazy Purple PPG # 2210 in the past you had 2 ALTernate formula tints, which one was correct?....you now had 2 shade/tint formulas that tweaked the color (reason why you see so many different shades of purple at a show, or when you go back for more paint, the color is off, even though the same guy/place mixed it before)...TODAY the PPG computer mix program for FC7 PPG 2210 Plum Crazy will call up and interface the PPG paint code 5463, although it will print PPG code 2210 for the mix label, the actual formula for the base, binder, balancer, tints, flop control agents, etc, etc will be for PPG 5463, a color PPG has determined to be "close enough" for you the consumer, so much for "accuracy"...
Like I said before there's no magical mix formula, from PPG or anyone, anymore, been that way from day one, any paint mfg's paint line can be made to match...even back in the day, when all we sprayed was enamel single stage, regardless of mfg, PPG, Dupont, Ditzsler, BASF, etc, etc all had ALTernate formulas to achieve a "match" so the mixer wasn't playing chemist to achieve a match, high end body shops would mix their own paint and tint accordingly to "match", but that was more for color blending of a repair than a revered restoration color match that most like to invoke today,
you want an accurate color match?, regardless of the paint mfg, you need a clean undisturbed area/component from the vehicle if you have it that hasn't been effected by degradation ....otherwise you stuck researching the color needed from the mfg you desire....going to the "original" OEM supplier is no guarantee of a color formula that is correct....back in the day, and even today the auto mfg's buy paint in vast bulk, do you think every vehicle produced week after week, month after month in the "same" color is the same EXACT shade of paint sprayed?...certainly not
Mike
