Then I went to external belt driven oil pumps with a wet sump pan because it is more reliable than a screwed in pickup or welded in like mine were pickups.
Are you running this setup in your STREET CARS ??
No but a 500+hp hemi should be able to put down some power and maybe shake the tires even on the street?
