If you look at the picture of the switch you just want the very top of the button exposed. You will see it is a two stage travel...one is a very small movement...the second is the whole length of the shaft. You want to shim it to the first stage. Mine is though a hole in the steering wheel...get creative..
5.53 @ 125 1/8th on the launch control..more left in her!
