What button...front tire pressure....front end limited?...there are quite a few other easy and almost free things you can do.
I am all for free and easy lol
Front tires are usually at 31-32lbs...never changes from there. They are sportsman fronts, but I am going to be changing to M&H drag fronts
I am using a hurst pistol grip pro stick shifter with the button that it came with
My front end as just over 5" of travel as that is what has worked best with the caltracs
