So if someone borrows your socket and decides to keep it that's o.k. under your set of morals right
Gus
Did you miss the part where you have to leave a deposit to rent the tool and the deposit is enough to cover the cost of the tool (in this case a socket)?
If a person buys a socket from the parts store uses it once and then returns it for a full refund it's no longer a new item and can't be sold a such.
If they have a rental tool and someone rents it once they've paid for the tool in most case (a socket especially).
The next time it's rented it's pure profit.
If the tool renter decides it's better to keep it for the deposit price (which is usually enough to cover it's replacement at the parts store) the store simply replaces it with one off the shelf.
The store essentially sold a used socket and got paid for a new one.
It's not a hard concept to grasp.
The "concept" some of you can't seem to grasp is a verbal or written agreement that you are renting a tool with the understanding that you will return it when you are done.
Thieves are too ignorant or unskilled to make the money to buy the tool they need, either that or they lack the moral compass to honor a contract ,which category do you fall into?
Gus
The auto parts store know full well up front that the tool may not be returned when they rent it.
They took a deposit large enough to cover the cost of it's replacement.
As has been stated, they don't really care if you bring it back.
They got paid for it by the deposit you made on it!
Gus, if you're posting from work aren't you essentially stealing from your employer by being on Moparts when you're supposed to be working?
Whether they care if you bring it back or the deposit covers the cost of the tool does not make it any less stolen if you in fact rented it and I'm pretty sure Gus works in a flat rate shop.
Kevin
