It just sounds like it has solid lifters in it. I have tried 1/2-3/4-1 full turn and it still clicks like its out of adjustment. I understand the aluminum roller rockers may make it noisy.
How are you adjsuting them, hot or cold? Are the heads aluminum ot iron? If aluminum make sure and set the preload hot I run a Comp Cams XE295HL cam and lifters in one of my 440 with Eddy RPM heads and Harland Sharp 1.5 rockers, nothing noisy in the valve train on it
