I had to notch my frame rails in an A body to fit a 29x19 dual pass rad from Speedway Motors for around $180. then I used 2 ebay fans that cost $15 each. one was a 14" and the other was a 12" set up as pullers
also ran a 10" pusher in front of the trans cooler
a shroud hurt my car going down the hwy when the combo was in a different car
Gen 3 power 6.22@110, 9.85@135
Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
