There isn't a lot of space between the Meizer water pump and the rad. Sticking a big fan dead center of the rad is not going to happen.
Even if you went with a 1.5" core rad, I doubt that set up will make it. Assume you have the rad stepped off from the core support to fit the front mounted electric fan - and it is staggered to the right? You are still missing a lot of the rad core. The rad core needs to be tight up to the core support so what ever air goes through the rad is ONLY coming from outside the engine compartment. Consider revamping your set up. It obviously aint working as it is. If you don't want to run a flex fan, move the rad up against the core support (make sure the core support opening is the same size as the rad core) and run one electric fan mounted to a fan shroud that looks and fits like mine. You need to draw air through the entire rad core.
Fastest 300
