Re: 440 Compression Test Results-Head Gasket or ???
[Re: Mr.Yuck]
#1436707
05/17/13 11:08 AM
05/17/13 11:08 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Why are you removing freeze plugs ? and no they are not reusable.
there is an NPT plug in the side of the block , in the middle and about half way up between 2 freeze plugs , this is what you remove to drain down the block , draining the radiator uaully only dranins it down to the bottom water pump hole.
You ca take off the lower radiator hose and jack up the rear of the car as high as possible, this will drain more of the block ....
what he said... you can also jack the side of the car up you are working on, but then you will need a stool or something to stand on.
Doh! I did not know there was a regular plug, I assumed it was a freeze plug, and we know what happens when you assume... thanks!
