Re: 440 Compression Test Results-Head Gasket or ???
[Re: challenger70]
#1436697
05/16/13 12:04 PM
05/16/13 12:04 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Do both sides, drain the radiator, pull the valve covers, intake, spark plugs, rocker arms and exhaust. Dont disassemble the rocker arms, pull them as a unit and lay inside a valve cover with the bolts still in it. unbolt the head bolts and lift off. I personally prefer the steel shim gaskets, but everyone will like something different.. If you run into trouble, I am pretty close by and can swing by. One of the posters mentioned torching, that is when the lit gases travel from one cylinder to another and erode a portion of the block.
Thanks, out of curiousity these steps all make sense except pulling the shaft rocker system off the heads. Is that neccasary to remove the heads? Just curious what this step accomplishes, thanks for the advice, explanation and help
How would you get the pushrods out if you didn't pull the rockers ? How would you hold the pushrods upright so you could get the head back on if you left the rockers in place ?
