Quote: Should I do both head gaskets while I am at it?
No unless milling is required on the block on that side of the deck then of course it'll all have to be stripped/eng pulled & redone with both new head gaskets etc & might be a good idea to have both decks milled at that time or even both square decked depending on what you want & they will for sure check the other deck when they get it in the shop
