Re: How long would a 7 1/4" last... . . .
[Re: Rick_Ehrenberg]
#1393856
02/28/13 09:06 AM
02/28/13 09:06 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Actually, worst case is like what happened to me - my transmission tail shaft snapped in two when the 7-1/4 failed and locked up, and made having to replace the rear end costing me a new transmission as well. That was an expensive lesson learned. Worst part was, I had a good 8-3/4" with 3.23 sure grip laying around but was too lazy to change the rear when i changed the engine from the tired 318 to the nicely built 360 with T/A heads.
Ok. Best case, when your 7 1/4 finally gives up, you'll be forced to install an 8 3/4.
Worst case, anything beyond best case.
To me, simple economics dictates doing the swap ASAP. Besides the potential overrunning clutch / output shaft / extension housing tranny costs, there's this simple fact:
A serviceable 7-1/4" has some valve, even if only as trade bait. A blown up one is just scrap iron, to be melted into more Hyundais and Prisus'.
No bucks for an 8-3/4"? Find an 8-1/4" the right width (Dakota? Cherokee?)
Rick
RICK! I'm honored.
I have to debate your one point though... Here, where i am, a 7 1/4" has NO value. Nothing. Only the toothless cockroach scrap-metal thieves eyeing my backyard would find value in it. You cant sell ANYTHING here anymore. I sat on a really nice drum-to drum 8 3/4" for 3 years because no one would give me $150 for it. Before that the previous two 8 3/4's (E-body and A-body) sat as long because i wanted just a bit more.
I would love to find a loving home for all this rather rare E-body 6-cyl stuff... but in my moments ov lucidity i know that i will be buried with it...
And i HAVE a nearly NOS 8 3/4" housing and axles i've hoarded for THIS car... been under a workbench since 1971. Just have no pig, no shaft, and no rear brakes, nor the money to rebuild it with all the little (yet surprisingly costly) stuff it needs. I even have new leafs for it (yet again, no hardware for them either).
