I run a lot of Indy stuff, that being said I buy it from a dealer which machines it as needed. Why deal direct from Indy if you knew from reading here how you would be treated. I bought a Dart block and Brodix heads for my brother in laws boat, they both needed machining also. Good luck on the new job Josh, I will give you a shot.
