Quote: Remember when you go roller you have to also think about spring pressure and rocker arms breaking. I had to go to t&ds after 3 sets of pushrods due to lack of oiling and 2 broken rocker arms.
What did you have before? I am running Hughes 1.6 ratio right now, and thought they should be okay?
Indy's 1.6. Bullet cam 668 lift which made it around 700 with close to 700 open psi and 270 or 280 on the seat.When i went to the t&d's i went back to 1.5's for a little less valvetrain stress. K950 springs.
Damn, those valve springs your using aren't cheap man Wasn't thinking valvesprings for a solid roller deal would cost that much.
As for my rockers, I thought the Hughes were supposed to be a good rocker and handle some serious stuff since Hughes totes them as being just as good as the high end stuff
