Quote: MRL came up with some that he says live on the street fine.
Yea, I was actually going to mention those. They are apparently drop in, and they seem to be pressure fed oiling even on the lower end model he sells.
I tried searching on here about them, but there is nothing. Maybe they are still to new?
Im just curious though if the pressure fed oiling to the rollers is even needed. I mean, standard flat tappet stuff only gets splash oiling anyways, so why does the roller stuff need more?
