Quote: Morels are good Solid lifters, Doug Herbert sells them very reasonably. The body seems to be a good bit longer than other brands so the pushrod winds up being shorter (i.e. stiffer for a given cross section) which should be theoretically advantageous....though less so on a 59 degree valley angle (increases the pushrod arc). I've spun my 414 to about 7200....so far.
Wize those are the lifters I was looking at. Previous posts on here said they were reasonably priced around $300 but my question is are they sufficient for lots of street miles based on their design and oiling characteristics compared tomorro expensive lifters?
