That is the bracket you will need. As for where it gets welded, that depends on the rotor used. From what I can tell the hat of the Jeep rotor is deeper then the Explorer rotor. That will change the location of the caliper, and where the mounting bracket is located.
Jeff
well i guess i will wait and see which rotor you use.lol also i think you have a dana 60 in your car right? my car has a 8-3/4 with moser axles and green bearings. so i wonder if the measurements would be in the same place? probably not just asking. also what do you do about the backing plates for the drum breaks? i mean can you just pull them off and bolt the axle back to the axle housing?? sorry for all the questions.Bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
