Quote: If you don't mind me asking why don't you fix the truck? The damage doesn't look too horrible. If you really like the truck fix it and pocket some cash.
The entire cab would need to be replaced. It crushed the dash down into the console and you can see the sheet metal buckled inside right above and behind the rear door. I would bet money it is more work than it is worth to fix.
