Re: 4.7l into classic Mopar?
[Re: Furious65]
#1313082
10/01/12 01:24 AM
10/01/12 01:24 AM
Posts: 21,318 Manitoba, Canada
DaytonaTurbo
Manitoba, Canada
Why the flash for the ECU? If I use all the 4.7 controls and such I don't see why I would need to unless I start adding some performance mods. Am I missing something?
Are you also going to put in every scrap of wiring from the dakota? That 05 computer is expecting to communicate with the body computer, anti-theft system, gauge cluster, all the emissions equipment, etc. Take any of this stuff away and you will have problems, unless you get it flashed. 1996+ when OBD2 came around, swapping the electronics over became a nightmare. The wiring is a lot more complicated to dissect and the computer needs to be flashed to ignore all the stuff that will be missing in your new vehicle. The 95 and back stuff can be done much easier. I swapped in a 99 engine but used 95 electronics for just this reason.
