Thanks to all for the encouragement. I'll have to see what the buy back cost is and go from there. Anybody know offhand what options are available to wake this engine up a bit? I know it would end up with a set of true duals, dual cats, maybe some air filter/air intake mods, and what ever else might be necessary.
You will need to either go to an aftermarket EFI controller or dissect the stock wiring harness, wire it in, then send your stock ECU out to be flashed. As-is, it would not run out of the vehicle.
Why the flash for the ECU? If I use all the 4.7 controls and such I don't see why I would need to unless I start adding some performance mods. Am I missing something?
since u have the whole truck go for it.. but check out your timing system while the engine is out..
Known issue or something else?
