This is just a quick fix....OK...Ill just ditch the mechanical.
But Id like to understand why it is not adviseable....I have seen people do it with no problems.....
If you have the electric pump plumbed in series the mechanical is going to have to suck through that vane pump which isn't going to work very well at all.
I know there's no problem with the carter pumps, i got the idea from the old direct connection book (13 second build). I never tried it with a Holley pump.
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
