Hi!
Last time I hit the track with my stock 71 440-6 car I think I had some fuel starvation issues....
When I was in 3rd gear and peak RPMs I had the motor die intermitently, kinda like if the cylinders were getting no spark....thing is, when the car is driven normally that never happens, so what Im guessing is that on a pass at wide open throttle Im sucking dry the 6 pack fuel bowls....am I thinking right???
Well, now to fix this I was wondering if I could run a Holley Blue pump (I already have it) out of the gas tank and then pump it through the stock mechanical pump.
I would like to avoid removing the stock mechanical if possible.
I would only turn the electric pump for ging down the 1/4 mile.
Can I do it like that?
Thanks!
