Re: Car stalls, then restarts
[Re: RawnDart]
#1272672
07/23/12 08:36 PM
07/23/12 08:36 PM
Posts: 28,312 Cincinnati, Ohio
Challenger 1
Cincinnati, Ohio
The coil could be the problem, you can check with an ohm meter. Also check the connector where the ignition switch plugs into the dash harness on the steering column.
I was having the exact same issue as you, and I found the pin burned on the red wire.
very good point/suggestion. ![](/ubbthreads/images/graemlins/thumbs.gif) Also check the firewall connectors making sure there plugged in right. 20 plus years ago I soldered the big red wire togeather under the steering coluum, end of that problem. I cut a zip tie off to get these pictures and pulled up some shrink wrap so you can make out the red wire. with a bigger peice of shrink wrap around it and I zip tie it to the coluum. ![](http://i21.photobucket.com/albums/b260/challenger19711/June%2023-11%20and%20after/SDC16692.jpg)
Entire Thread
tcat446
07/23/12 07:03 PM
RapidRobert
07/23/12 09:57 PM
tcat446
07/23/12 10:42 PM
rbmopar
07/23/12 10:04 PM
Challenger 1
07/23/12 10:24 PM
tcat446
07/23/12 10:44 PM
Challenger 1
07/23/12 11:01 PM
Theorio1025
07/23/12 11:05 PM
tcat446
07/23/12 11:12 PM
Challenger 1
07/23/12 11:15 PM
Challenger 1
07/23/12 11:19 PM
tcat446
07/23/12 11:21 PM
RawnDart
07/24/12 12:01 AM
Challenger 1
07/24/12 12:36 AM
RawnDart
07/24/12 02:10 AM
tcat446
07/24/12 02:25 AM
tcat446
07/25/12 12:53 AM
tcat446
07/24/12 12:49 AM
tcat446
07/24/12 12:53 AM
tcat446
07/24/12 01:02 AM
Pacnorthcuda
07/24/12 01:04 AM
tcat446
07/24/12 01:16 AM
tcat446
07/24/12 02:03 AM
tcat446
07/24/12 12:34 AM
Challenger 1
07/24/12 12:52 AM
RapidRobert
07/24/12 12:24 AM
tcat446
07/24/12 12:33 AM
RapidRobert
07/24/12 12:41 AM
zrxkawboy
07/23/12 11:08 PM
tcat446
07/23/12 11:13 PM
tcat446
08/03/12 02:22 PM
Challenger 1
07/23/12 11:12 PM
tcat446
07/23/12 11:14 PM
FASTBACK340
08/04/12 11:10 AM
tcat446
08/04/12 04:13 PM
stumpy
08/04/12 04:58 PM
Challenger 1
08/04/12 05:25 PM
tcat446
08/04/12 08:13 PM
