Quote: Hay Kevin, yes it's been two years since i got the car and had a ball racing again as it's been about twenty years between runs. The car weighs 3630 with me in, standard springs that have been reset down, with kyb gas adjustable shocks on rear and standard shocks on the front. It launched fairly even and straight.
I agree on the duration being big for you...get the front loose so it will lift and transfer the weight.. that will help your 60'(your probably spinning with a 1.72)
