as Dr. Diff said, for a street car, 2 degrees nose down relative to the tranny output shaft is good for a street car
OK so if the trans is 2 deg down from level you'd want the pinion 2 deg up (parallel) plus the 2 deg nose down added in that you mentioned for a total of zero (level) for the pinion? or were you saying pinion 2 deg further down than the trans say if the trans is 2 deg down then you'd want the pinion 4 deg down?
