yes they are the same EXCEPT the bellhousing is sized for a 13" or so converter. Because of that I am not sure if it's a little longer in the manicase.
What are you going to do about the electronics ?
Bellhousing is going to be an ultra bell. I am thinking full maual vb. I heard by using this I can get rid of most of the electronics and put the od/lockup on a switch. This will be going in a high hp street car.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
