It should be interesting as when I shifted it to move it back and forth in the garage it didn't want to go unless I played with the shifter. I wonder if Hurst is aware of these problems and maybe have a different length lever?
Mike, I was going to call up a few friends; but at -15 degrees they might not be my friends anymore. Hooked up some small tie-down straps to the stake pockets and used my engine cherry picker to off load it from the trailer. I plan on setting it on the truck in the next 2 days. I lifted one end and I think it would be a breeze with 4 people.
