yes a standerd long tail shaft 727 fits
center of trans mount bolts should be 7" from rear of trans case.
most short shafts have this same 7" distance and will work with the slip/spline drive shaft.
the BB 727 i have in my truck was from a 1 1/4 ton MH cassis,the center of mount bolts was 5"..I had to move my xmember foward 2" and build it from square stock and the lower support braces of the stock cross member.
it also used a early flat thin rubber trans mount like a 71 truck,the spedo was behind the mount and not in front so a stock xmember no worky.
that would be the only thing to watch for hunting,as long as the spaceing is 7" it bolts in.
glad you got the e-brake peice,i had no luck in the JY today for anything,nice walk in nice weather though
this 727 shorty was the first oddball one I have seen with the mount,speedo,huge 4 5/8 u-joint...the yoke did swap out to a 7260 though.
