Mini starter installed; had to shorten the electrical post and use part of the adapter so the cable will clear the block. Purchased a set of Ebay shorties for $189.00 and notched the frame a bit for clearance. The angled plugs clear the tubes but not by much. Straight plugged heads would have a lot of room for the boots. I am going to try some accel racing shorties to gain more boot clearance. The dipstick that I got with the truck pan would not work so I went to Napa and bought a 3/8" brake line that already had the double flare and nut on it. I put a few bends in it and made a bracket to secure to the header bolt. I am looking for a flexible dipstick indicator rather than cut the new one. It'll be for sale along a bunch of stuff soon. I plumbed in the fuel lines back to the (quiet) fuel pump. Here are a few pix.
