I have a stock 10.5 inch 130 tooth pressure plate that was rebuilt and a standard disc going through a dana 60 using a dana 70 3.55 gears. This is going through a 23 spline 3.09 gearset if I can come up with all the parts. I still need a main shaft and a good input shaft. Tim
