Quote: My clutch locks on the launch,... tires spin for about a car length. Still enough to lift the front tires off the ground and pull down 1.60 60' times.
So you can dump the clutch at 6k and not burn tire all the way down the track!
Can't do this on the street though!
Just thought about this thread again after starting the thread on tricks to help with transmission strength/ life
