I have the trans that is fresh, that John Cope built for me...and I have a fresh 9 1/2" converter with a 4400 stall for the street...I haven't installed the gears yet which are 4.57's for the 9"...
the rear tires are 32" and I may go larger..I will be driving the car on the street and maybe a trip or two down the track...maybe I'll see you at drag week if I can over come diabetes that sorta makes me want to black out with a helmet on during hard acceleration..LOL
anyways..I was debating on changing the rear gear for something a bit in the 4.10 range or even higher..and with an OD unit, I could drive it anywhere...
thoughts??
I went with a 4.10 gear in a 9"... I am running a
295/55 tire and with the conv slippage and the OD I should
be tuning 2900 - 3000 at 75mph
