Quote: I also did not touch the booster but if that was bad, it should show itself as almost having manual brakes, right?
I could also block off the rear brakes completely and try operating with just the fronts to see exactly how well they perform.
(1) Yes I think pretty much so just like when you keep pressing them with the eng off. (2) Excellent idea to with a brass plug cap the rear brake port which'd be as you know the front port but I would cap both first. we gotta start somewhere to narrow this down
