My knowledge of bump steer is this. You need to form a parallelogram with these 4 points. The lower control arm pivot. The inner tie rod pivot. The lower ball joint pivot. And the outer tie rod pivot. Can you explain how raising the upper ball joint pivot affects this? I don't see it. Doug
Maybe this will help you see... ;->
Rick
So rather than just posting the picture how about explaining what it represents.... Cause the blue lines are more of a concern in bump steer & spindle height has a minimal effect on those... In my limited background the red lines are represent a angle that effects anti-dive characteristics allot more than bumpsteer... Why not tells us the what & why not just post a picture....
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
