It measured up good... I set it at .002 and .002 (mains and rods) with .007 end play.... I'm sure not use to 1/16" rings... man do they DRAG... I got 28 ft lbs to turn the assembly, my race stuff takes 18 ft lbs EDIT after playing with it I got the break away torque down to 24 ft lbs... those rings just drag alot
