Go ahead and order lifters...
I don't know how to read this. Do you feel like I'm wasting money buying lifters, or do you think I messed with it too much and really need lifters? I'm tired of chasing my tail.
Michael
You need shorter pushrods on some valves, plain and simple. If you don't have adjustable rockers to compensate for variances valve to valve.
There ain't anything wrong with your lifters.
Hopefully you didn't hurt a lifter or cam lobe by running it with not enough lash. They all should be checked. Easiest way is with the intake off. Set em once and forget about them for life of the motor with a hydralic cam with adjustable rockers.
You need to take a adjustable pushrod and see what length you need and compare that with the pushrods you're running now. I bet there too long.
