Put it in a vice, take the blade off a hack saw, put it through the sleeve, reattach blade to hacksaw... then cut the sleeve out.
Try that & you'll be cutting the control arm... There is a step between the back of the pocket that receives the bushing & the pocket that receives the torsion bar...
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
