You can notch/cut the inside of the LCA sleeve with a sawzall. Then a hammer and chisel or air chisel to fold the outer lip into the center of the sleeve and it will fall out.
If you have a press, remove the inner sleeve and bushing, then put a washer almost the size of the ID of the outer sleeve into the sleeve. Take an air chisel and fold over the lip of the outer sleeve to hold the washer in place. Then press it out. The washer should come out once the sleeve is off the LCA.
